Vs: ajeleeko kukaan 8 lämpöarvon tulpilla?
Niin sanoo, mutta Matt sano ja tais Ray.P sanoa että ei pidä paikkaansa ;D
Eli toimii
Posted by Ninja Performance View Post
I love learning, and this may be a opportunity to learn.
As noted by another, Ray has always used DLIs with non resistor plugs with no issues. I don't think he ever mentioned doing anything special like the notch filter you mention. I too have used a DLI for a very long time. My current setup, using a DLI I started using probably 4 years ago, all it has ever seen is non resistor NGK coppers, and now the champion C53VC surface discharge plugs which are non resistor.
I always run around 35-36psi. Street and drag strip. Never a hiccup.
So what is the actual issue? I know HKS has always stated no for use with non resisotor plugs. But is this just HKS covering their butts since non resistor plugs by nature will cause EMI and maybe ruin your AM radio reception. Does the DLI increase this effect so the don't want to risk it. Of course strong enough can disrupt an ECU, but again, never seen any issues or heard of any.
Please share with the class, I am all about learning.
-Chris "
