Bee R 420a Eclipseen
227
Vs: Bee R 420a Eclipseen
En oo varma onko oikea mutta ehkä tästä on apua:
Pin Number Wire Color Use
1 Unused Unused
2 Unused Unused
3 Brown To Coil 2/4
4 Unused Unused
5 unused unused
6 Black / red stripe From ASD relay
7 Yellow / green stripe Injector #3
8 Blue To Generator Field Coil
9 Blue / Yellow Stripe to Brake Warning light
10 Black Ground
11 Black / Blue Stripe To Coil 1/3
12 Red / Black Cruise Control main switch
13 Light Green / Black stripe Injector #1
14 unused unused
15 unused unused
16 light green / red stripe Injector #4
17 Yellow / Red Stripe Injector #2
18 Light Green Not Sure Yet
19 Green / orange stripe to radiator fan relay HIGH
20 Black / White stripe ECU main power
21 unused unused
22 Green / Red Stripe To CEL Light
23 Yellow / Blue stripe To fuel gauge and Low Fuel light
24 Unused Unused
25 White / Yellow Stripe Knock Sensor Signal
26 Green / White stripe Engine Coolant Temperature sensor input
27 unused unused
28 unused unused
29 unused unused
30 White / Blackstripe Front O2 sensor signal
31 unused unused
32 Blue / White stripe Crankshaft Position Sensor signal
33 Blue / Red stripe Camshaft Position Sensor signal
34 unused unused
35 Brown / Red stripe Throttle Position Sensor signal
36 Yellow / Black stripe MAP Sensor signal
37 Brown / Blue stripe Intake Air Temperature Sensor input
38 Green / Red stripe to AC dual pressure switch
39 Blue To Battery Light
40 Red / Blue stripe to EGR solinoid
41 Red Cruise Control switch
42 unused unused
43 Black / Green stripe Ground for VSS, MAP, TPS, CmPS, CkpS
44 Yellow power for VSS, CrPS, CmPS (8v+)
45 Blue / yellow stripe Power Steering Pressure Switch
46 Red / Black stripe to ASD relay
47 Black Ground
48 Green / Blue stripe to IAC pin 2
49 Orange / Blue stripe to IAC pin 3
50 Black Ground
51 White / Green stripe Rear O2 sensor signal
52 unused unused
53 unused unused
54 unused unused
55 Green / black stripe Radiator fan relay LOW
56 Light Green / White stripe To Cruise Control
57 Grey to IAC pin 4
58 Yellow / blue stripe to IAC pin 1
59 Black / Blue stripe To coil 1
60 White / blue stripe to TCU (ATX only) and/or OBD1 connector
61 Green / yellow stripe Power for MAP, TPS (5v+)
62 Brown / White stripe from stoplight switch
63 unused (MTX) or Orange / Black stripe (ATX) to TCU (ATX)
64 Green to AC compressor clutch relay
65 Pink to OBD2 connector
66 Yellow / white stripe VSS Signal
67 Red / white stripe to ASD relay
68 Light Green / black stripe to duty cycle purge solinoid
69 Green / orange stripe Condensor fan relay HI
70 Black / White Stripe To Duty Cycle Purge Solinoid
71 unused unused
72 Red / Blue stripe to EVAP solinoid
73 White Tach signal to HVAC ECU and Gauge cluster
74 White / red stripe to fuel pump relay
75 Blue / black stripe to OBD1 connector
76 Black / yellow stripe (ATX) or unused (MTX) to transaxle range switch (ATX) or unused (MTX)
77 Red / yellow stripe to EVAP solinoid
78 Unused Unused
79 unused unused
80 Black / yellow stripe to cruise control speed control assembly
DaJackal
EA5A, Z16A, CB4A, D22, E39A
10 Huhtikuu 2010
2
Lappeenranta
Ja ylläolevahan pätee vain jos on '97 mallinen. 95-96 mallissa on 60pin, ja 98-99 taas eri ECU.
http://www.2gnt.com/index.php?d=ECU_Pinout
http://www.2gnt.com/index.php?d=1995_ECU
DaJackal
10 Huhtikuu 2010
2
Lappeenranta
#5
Basbarduu sanoi
TuplaNokalla on -97 allekirjoituksen perusteella.
Osasin Sherlockina kyllä päätellä tämän, mutta näitä Eclipsejä on nähty useampia missä rekisteröintivuosi laahaa todellisesta vuoden tai kaksikin perässä.
TuplaNokka
PunkkaRacingTeam
1 Helmikuu 2015
26
Riihimäki
#6
DaJackal sanoi
DaJackal on oikeassa, mutta se on joko 97 tai 98
