Bee R 420a Eclipseen
Vs: Bee R 420a Eclipseen
En oo varma onko oikea mutta ehkä tästä on apua:
Pin Number Wire Color Use
1 Unused Unused
2 Unused Unused
3 Brown To Coil 2/4
4 Unused Unused
5 unused unused
6 Black / red stripe From ASD relay
7 Yellow / green stripe Injector #3
8 Blue To Generator Field Coil
9 Blue / Yellow Stripe to Brake Warning light
10 Black Ground
11 Black / Blue Stripe To Coil 1/3
12 Red / Black Cruise Control main switch
13 Light Green / Black stripe Injector #1
14 unused unused
15 unused unused
16 light green / red stripe Injector #4
17 Yellow / Red Stripe Injector #2
18 Light Green Not Sure Yet
19 Green / orange stripe to radiator fan relay HIGH
20 Black / White stripe ECU main power
21 unused unused
22 Green / Red Stripe To CEL Light
23 Yellow / Blue stripe To fuel gauge and Low Fuel light
24 Unused Unused
25 White / Yellow Stripe Knock Sensor Signal
26 Green / White stripe Engine Coolant Temperature sensor input
27 unused unused
28 unused unused
29 unused unused
30 White / Blackstripe Front O2 sensor signal
31 unused unused
32 Blue / White stripe Crankshaft Position Sensor signal
33 Blue / Red stripe Camshaft Position Sensor signal
34 unused unused
35 Brown / Red stripe Throttle Position Sensor signal
36 Yellow / Black stripe MAP Sensor signal
37 Brown / Blue stripe Intake Air Temperature Sensor input
38 Green / Red stripe to AC dual pressure switch
39 Blue To Battery Light
40 Red / Blue stripe to EGR solinoid
41 Red Cruise Control switch
42 unused unused
43 Black / Green stripe Ground for VSS, MAP, TPS, CmPS, CkpS
44 Yellow power for VSS, CrPS, CmPS (8v+)
45 Blue / yellow stripe Power Steering Pressure Switch
46 Red / Black stripe to ASD relay
47 Black Ground
48 Green / Blue stripe to IAC pin 2
49 Orange / Blue stripe to IAC pin 3
50 Black Ground
51 White / Green stripe Rear O2 sensor signal
52 unused unused
53 unused unused
54 unused unused
55 Green / black stripe Radiator fan relay LOW
56 Light Green / White stripe To Cruise Control
57 Grey to IAC pin 4
58 Yellow / blue stripe to IAC pin 1
59 Black / Blue stripe To coil 1
60 White / blue stripe to TCU (ATX only) and/or OBD1 connector
61 Green / yellow stripe Power for MAP, TPS (5v+)
62 Brown / White stripe from stoplight switch
63 unused (MTX) or Orange / Black stripe (ATX) to TCU (ATX)
64 Green to AC compressor clutch relay
65 Pink to OBD2 connector
66 Yellow / white stripe VSS Signal
67 Red / white stripe to ASD relay
68 Light Green / black stripe to duty cycle purge solinoid
69 Green / orange stripe Condensor fan relay HI
70 Black / White Stripe To Duty Cycle Purge Solinoid
71 unused unused
72 Red / Blue stripe to EVAP solinoid
73 White Tach signal to HVAC ECU and Gauge cluster
74 White / red stripe to fuel pump relay
75 Blue / black stripe to OBD1 connector
76 Black / yellow stripe (ATX) or unused (MTX) to transaxle range switch (ATX) or unused (MTX)
77 Red / yellow stripe to EVAP solinoid
78 Unused Unused
79 unused unused
80 Black / yellow stripe to cruise control speed control assembly
Ja ylläolevahan pätee vain jos on '97 mallinen. 95-96 mallissa on 60pin, ja 98-99 taas eri ECU.
http://www.2gnt.com/index.php?d=ECU_Pinout
http://www.2gnt.com/index.php?d=1995_ECU
TuplaNokalla on -97 allekirjoituksen perusteella.
Basbarduu sanoi
Osasin Sherlockina kyllä päätellä tämän, mutta näitä Eclipsejä on nähty useampia missä rekisteröintivuosi laahaa todellisesta vuoden tai kaksikin perässä.
DaJackal sanoi
DaJackal on oikeassa, mutta se on joko 97 tai 98
