Mitsubishi Galant 1987 E15 2.0Turbo RalliArt
28 Toukokuu 2015
Zagreb, Croatia
#51
Vs: Mitsubishi Galant 1987 E15 2.0Turbo RalliArt
Here are the pics of the full respray, car was mostly flat AFTER 28 years, little here and there some dent etc.
colour is original ,Sarajevo Weis W18, but in clear coat it was added a bit of a crystal gold pearl, without sun or light you cant see it, it turned out very very good, and I was very satisfied with that.
preparing the car for painting
Preimer:
Ready for paint
Colour:
Painted :D
And some better pics after it got home :)
Some closer view
28 Toukokuu 2015
Zagreb, Croatia
#54
Slowly coming back together
a lot of time and effort goes for polishing
But first, PAINT protection , sealant and wax from soft99 fusso
Also cavity wax for doors and under the car
More cinced parts (some of)
polished edge on the tail light
Got a brand new HELLA rear plate lights with chrome look
little before after
And a rear end DONE!
Skydiver
20 Tammikuu 2005
Kerava
#55
Love the way You pay attention to the details. :peukku So that's why You have to repaint the jack too 8)
28 Toukokuu 2015
Zagreb, Croatia
#56
Little update, trunk is completed, also an interior and the doors, every little thing was polished, galvanized bolts etc, it takes a lot of time for that (for doors I have spend 2weeks of every day work)
Side skirts are ON :D
Interior COMPLETE
Front light renewd , galvanised bolts etc.
28 Toukokuu 2015
Zagreb, Croatia
#57
Got some time to finish my custom made mud flaps, base design was for an EVO6
And FRONT end finished, it looks so clean now, better than new :D
here is the pic i like the most :D
And one with all lights ON
28 Toukokuu 2015
Zagreb, Croatia
#61
Time for new exhaust full 70mm exhaust, with electric cutout on the rear muffler ( for quieter and louder mode), and polished 80mm exit
So here is my design
two pipes through the rear muffler (bigger one(70mm on the electric cutout side, without holes on it), and smaller one (60mm, where gasses are going when cutout is closed(with holes in it, so the muffler can absorb sounds)
remember , the angle of those two pipes is very important, the bigger angle you got, the louder car will be when the cutout is opened
Next thing to do is to port a turbo housing, this needs to be done to prevent boost creep, here it is how it looks before and after around wastegate
Later i had problems with a hot air when boosting. As the car still isnt mapped, and its in brake in proceduree hot air is allready a problem, so it would be big problem during the mapping
So i got almost a brand new intercooler from EVO10
And one video how electric cutout work(sounds)
this is without middle muffler, so basically when electric cutout is opened it simulates straight pipe
https://www.youtube.com/watch?v=30WK_nj8n_c
MakeM
2 Elokuu 2008
3
#62
I'm also having a boost creep problem with my Evo 3. How much porting did you do to solve the problem?
I heard the stock one is around 22mm diameter, and the flapper is 28mm or so.
28 Toukokuu 2015
Zagreb, Croatia
#63
hy
the problem is here because you have upgrade your exhaust and probably your intake pipes and cooler.
during the mapping, boost creep is still visible(but not that much) but for completelly elimination I have used electronic boost controller
problem is the position of the wastegate. it is placed 90degrees on the air flow which is bad, so you need to smooth the edges as far as you think you can
the hole on the wastegate is 28mm, flapper is I think 32 or 34mm, cant remember now, mine is from EVO2 but should be the same on yours
so the best solution for this is to go on external wastegate, in that way you will get the best boost controll, but i want everything look stock
MakeM
2 Elokuu 2008
3
#64
Yep, I thought that 65mm downpipe with race cat wouldn't be too big, but I was wrong ;D
How far was your setup creeping before and after porting?
External wastegate would be ideal for any turbo setup, but I don't really want to modify my car that much at this point.
I love the response, torque and spool that the bigger exhaust gives, so wouldn't want to go smaller either.
Maybe support mods and E85 for fuel to fight knocking? ;D
28 Toukokuu 2015
Zagreb, Croatia
#65
well i cant answer on that question because i knew what is happening if you dont port your turbo. so i have ported it before mapping
well with external wastegate you wont loose spool or torque, instead you will get better spool (it will spool sooner for lets say 50-100rpm) you wont notice that, but on paper it will be better
because stock wastegate isnt shut 100%, because of the age the surfaces arent flat anymore
+ you will get great boost controll when boost hits
however i recommend you to upgrade to electronic boost controller in that way you almost wont have boost creep, with ecm link offcourse
http://www.ecmtuning.com/product_info.php?products_id=54
28 Toukokuu 2015
Zagreb, Croatia
#66
Intercooler fits perfectlly
it is 3times bigger than the old one
oil cooler was also relocatted
here how the intercooler looks after redoing the pipes, also a SPAL fan was added for better cooling
Electronic boost controller is installed also
and i got a throttle body from an evo8, much better and faster TPS and ISC sensors
28 Toukokuu 2015
Zagreb, Croatia
#67
Next, i had to make adapter for ISC to the Eclipse/ early EVO installation
also i had boost leaks on throttle body, and on the outlet of a turbo, so a new flange has been made
Rebuild kit for throtle body
Next i got very lucky and found a brand new middle blend for redesign version complete with instructions and install hardware
also i got a brand new right tail lamp
to me looks much better with it :)
28 Toukokuu 2015
Zagreb, Croatia
#69
another CRASH, fortunately a very light one, Opel didnt pass well haha
All repaired now :)
one with mine second Sapporo with ECS (Electronic controlled suspension)
nice turnup one evening
and meeting with a friend of mine (normal vs RalliArt)
next thing i got is pieces for suspension upgrade
much larger holder bracket for front subframe
and poly bushings for front end
cubeqtio
Mr. Cube
Toimihenkilö
28 Tammikuu 2009
6
#72
Like I said on Facebook - liking this one! :)
MakeM
2 Elokuu 2008
3
#73
Seems to me, that the torque is at quite high RPM and it's a bit down on power.
Of course I'm comparing that to Evos, but can there be as much mechanical difference?
For example, an Evo 3 from the club had highest torque at 3600rpm (430 Nm) on 1 bar boost and after that it slowly tapered down to 300 Nm at redline.
Could the porting affect spool somehow, or is there something else?
28 Toukokuu 2015
Zagreb, Croatia
#74
Yep, its a huge mechanical difference between 6bolt and 7bolt, for stock engines of course
6bolt angine has 7.8compression ratio
Evo1-2 8.5compression ratio
Evo3 9.0compression ratio
Thats a huge difference, especially for nowdays fuel
Iam running on 1.3bar
Porting is made because of a boost creep, spool cant be much better, with the same turbo
MakeM
2 Elokuu 2008
3
#75
Tomica93 sanoi
Do you have a boost graph? Or when does it build the desired boost pressure?
Seems to me that you have something wrong with the setup. Don't take this personally, I love your build. Just trying to help :)
28 Toukokuu 2015
Zagreb, Croatia
#76
I have electronic boost controll, so iam limitating it doesnt hit hard(less stress for engine)
Setup is set this way
Till 2250rpm 0.5bar
2250-2750 0.7bar
2750-3250 1.1bar
3250- 1.3bar
But in real iam seeing 1.3bar on around 3900rpm
Its evo2turbo
What do you think its wrong?
28 Toukokuu 2015
Zagreb, Croatia
#79
Lets post a few updates
next thing for deal with was suspension and handling
Suspension was original, but all springs are worn out and old, rear shocks were leaking, and also the car was too soft to handle that kind of power so i upgrade it to much better level
Ive bought Cusco street ZERO coilovers for Lancer EVO III
car handles much much better in corners, over the holes its almost like stock suspension, over the speed bumps you have to be little gentle , overall very good coilover
Also got the powerflex camber bolts as the car sits little lower now
Got new oem bumper indicator lens
Then the next problem was grip, i had only 2 and a half years old tyres but they didnt have grip at all
So i bought new tyres Continental Contisportcontact 5 215/45/17, also as I will upgrade the brakes i need new wheels that are the same dimensions (17" , 7J , ET40) but with flatter spokes
that means more space for bigger brake calipers, luckily i found Superleggeras which are 4kg lighter than previous wheels EACH! and also they have 1,5cm more space for brake calipers
Cleaned up the wheels, waxed them, got new central rings 67,1mm and new lug nuts
And ready to fit on a car
Results are awesome, lighter steering wheel (as each wheel is lighter for 4kg), and much more grip, which allows me to run full boost in second gear afer 5000rpm
Also getting the parts for next work
new tie rods, new tie rod ends, new boots, new front bearings, new CV joints
28 Toukokuu 2015
Zagreb, Croatia
#81
Next update, got the brakes, 4pot brembos with braided steel lines and 320mm discs
redrilled discs to 4x114,3 and test fit, it fills up the 17" nicely
got new front bearing in, and also polyurethane on arms
Custom made heavier springs for trunk opening, as the factory didnt design it for trunk spoiler, now the trunk hood sits up alone :)
Another gearbox from 2.4 Galant is in with lower miles on it
also installed new OEM shaft seals
new clutch disk material
also new braided steel line for the slave clutch cylinder, you can see how worn out is the old one
and new slave clutch cylinder
T. Kiili
Mr. Cyborg
28 Helmikuu 2004
22
kotka
#82
i love the way you build your car. That is awesome!!
what front hubs you have, will they fit straight to brembos or are you going to do some adapters?
28 Toukokuu 2015
Zagreb, Croatia
#83
As you can see on the pictures they allready have adapters :)
Hubs are the same as eclipse/evo123/fto only bolt pattern is different 5x114(eclipse,fto)
28 Toukokuu 2015
Zagreb, Croatia
#86
Disassembled front subframe
Some new parts
Took out the bushings front front subframe, they were in really bad condition, as you can see on the picture, new oem ones are ready to pop in
also new stoppers
New gasket for fuel sender unit
New grommet for hood pin
Then i have to install new seals in the steering rack, and also new rod ties, rod tie ends and new boots
New boot for steering rack
Dont have picture when shafts were finished, but painted them to OEM colour
Painted brackets for front subframe
Installed and painted slave clutch cylinder
Custom made full rubber front engine mount
Polyurethane SuperPro bush on sway bar
Finally made an adapter for EVO ISC to DSM wire installation
AYE_GTI
15 Elokuu 2005
Tornio
#87
T. Kiili sanoi
Kuikahan hän on saanu nuo evo 3 takaiskarit sopimaan, et eikö nekin pitäs olla sen 10cm liian pitkät?
Sama hommaku sulla sen nelikon alustan kanssa...
T. Kiili
Mr. Cyborg
28 Helmikuu 2004
22
kotka
#88
AYE_GTI sanoi
Noissa coileissa on niin paljon säätövaraa että onnistuu kyllä. Kuhan sais omaan bc:t alle joku päivä ;D
28 Toukokuu 2015
Zagreb, Croatia
#89
Assembled complete front subframe, car really drives fantastic now, no sounds at all, and brakes, AWESOME, it has the stopping power now
also to make it a little softer i have made custom springs, front 5,6kg/mm and rears 3,5kg/mm
Calipers refurbed, new, bolts, paint and stickers, little before/after
It fitted very nice :D
New blood
At the geometry service
And got the fluidampr crank pulley & ARP bolts
cubeqtio
Mr. Cube
Toimihenkilö
28 Tammikuu 2009
6
#90
fluidampr is a gooood choise! Made a big difference in my car even on idle. Smoothens everything up.
28 Toukokuu 2015
Zagreb, Croatia
#91
yep, very good product
mine old pulley wasnt good anymore, the internal rubber fall off. and when i put the fluidampr, allmost all vibrations i had were gone.
also usually it is 320gbp at ross sport, and i catched very good deal of a 230gbp :)))
cubeqtio
Mr. Cube
Toimihenkilö
28 Tammikuu 2009
6
#92
Tomica93 sanoi
Good deal. :)
28 Toukokuu 2015
Zagreb, Croatia
#93
Few more updates
new rear steel brake feed lines
installed fluidampr crank pulley, and also new Gates, alternator and power steering belt
looks good underneath now :)
Got brand new OEM front grille
Adjustable rear dampers came in, Cusco, newer dampers, and also they are longer for 1cm, which means a little more street friendly
Comparasion to a non adjustable CUSCO
and one nice pic from the petrol station
28 Toukokuu 2015
Zagreb, Croatia
#95
Thats a good question.
I think the only part of a car that need more attention is the engine bay. Its first colour and white. You even cant wash it now properly. So a new paint would be needed , but i dont have in plan in any soon future to put out the engine and all other accessories just to paint the engine bay.
Also looking for the left NEW tail light. As mine has damage :)
There would be much more longer list if you are fussy as fuck, but keep in mind this is a very old and very rare, and the most important thing very unpopular car, so parts are very hard to find, but so far Iam incredibly very good at finding ones :D
28 Toukokuu 2015
Zagreb, Croatia
#96
Little update, havent been working on a car. I was driving it for a change, done over 3000km over the last 3months
In front of Pula Arena
then i was on a oldtimer meeting, with my dad(green 4gen Galant), and a good friend of mine with his RalliArt version also in white. That was a pretty cool sight
And some better photos of mine car :)
28 Toukokuu 2015
Zagreb, Croatia
#99
Couple more updates
Crankpreassure was next thing to deal with, no more oil dip stick popping out and inlet on turbo is now dry :)
so I have made a custom valve cover, drilled a much larger hole, and weld bigger fitting, removed PCV valve and also put a bigger one, but left the thread in case i will want to return PCV :)
after that, professional coat was apllied
difference between holes
New oil Catch can and silicone hose
Then few shots from the sea and driving :)
Then got new silicone clear hose for washerfluid line, so I have replaced an old ugly one :)
Thats all for now :)
28 Toukokuu 2015
Zagreb, Croatia
Next thing to deal with was the power windows switch.
First they started to fail on the main one (passanger window couldnt go up) and also letters worn out after years of using
First i have disassembled everything, cleaned up the contacts, and it all woreked again like a charm
Then i found a ultra rare JDM main power window switch that has Door Lock option on it and AUTO funstion for drivers window.
It was in Malaysia, and it is very very hard to communicate with them and in the end to get parts from
So i accepted a challenge of making a UNIQUE, only in the world, LHD main switch with AUTO power windows on drivers doors, and Door lock option
And finally received it after 2months
Next big problem was it was all for RHD (you cant put AUTO function on the left side) and also you need to use LHD plastic surround to fit properly
However plastic surround didnt have DOOR LOCKS sign
after days of researching, find up it wasnt a sticker on the buttons and plastic surround. It was printed with high quality colour that remains under usage of fingers
luckily i found one guy who was able to do this for me, so i have also refurbed buttons and plastic surround, also all other buttons on passanger doors
next thing about AUTO function. Mitsubishi Galant Sigma in USA had AUTO function on driver window as a LHD. luckily found one with broken plastic and cutted wires, but again seller didnt want to ship, so I had to find agents etc.
after 2more months finally item arrived
next problem was it didnt have DOOR LOCK, so i had to cut the JDM one and weld it with USA one
Next. all was working except AUTO function for driver window when it go UP.
Thing is, in the US there was a child proof law. so the button had some kind of restriction, and also 1wire was missing from the small control unit plate (white wire in the picture above was added).
When it all was solved , here is the final result
From 3very rare parts, I got 1 Unique with all functions working :)
Final result: astonishing :D
