Sytytyspuola. Mitä en nyt hoksaa : )
Deepak
21 Joulukuu 2017
Tässä olen etsiskelyt leguun noita sytytyspuolia, ja ausseista löyty yksi firma joka myy noita 60 e kpl hintaan. Mielenkiintoista asiasta tekee niiden soveltuvuus muihin mitsuhin. Teksti sivuilta:
NotesYearMakeModelSubmodelVariantEngine 2005MitsubishiLancerCG,CH,CJ Sedan 2.0 GDiFWD Petrol 2.0L 4cyl 92kW 4G94 (GDI)1999cc 92kW (Petrol) 2004MitsubishiLancerCG,CH,CJ Sedan 2.0 GDiFWD Petrol 2.0L 4cyl 92kW 4G94 (GDI)1999cc 92kW (Petrol) 2004MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 2004MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 2004MitsubishiOutlanderZE,ZF SUV 2.4 4WDAWD Petrol 2.4L 4cyl 102kW 4G64 (16V)2351cc 102kW (Petrol) 2003MitsubishiLancerCG,CH,CJ Sedan 2.0 GDiFWD Petrol 2.0L 4cyl 92kW 4G94 (GDI)1999cc 92kW (Petrol) 2003MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 2003MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 2003MitsubishiOutlanderZE,ZF SUV 2.4 4WDAWD Petrol 2.4L 4cyl 102kW 4G64 (16V)2351cc 102kW (Petrol) 2002MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 2002MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 2001MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 2001MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 2001MitsubishiPajero iOQA SUV 1.6 4WD (H65W)AWD Petrol 1.6L 4cyl 75kW 4G181584cc 75kW (Petrol) 2001MitsubishiPajero iOQA SUV 1.8 GDI All-wheel Drive (H66W, H76W)AWD Petrol 1.8L 4cyl 88kW 4G93 (GDI)1834cc 88kW (Petrol) 2000MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 2000MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 2000MitsubishiPajero iOQA SUV 1.6 4WD (H65W)AWD Petrol 1.6L 4cyl 75kW 4G181584cc 75kW (Petrol) 2000MitsubishiPajero iOQA SUV 1.8 GDI All-wheel Drive (H66W, H76W)AWD Petrol 1.8L 4cyl 88kW 4G93 (GDI)1834cc 88kW (Petrol) 1999MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol)
1999MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 1999MitsubishiPajero iOQA SUV 1.6 4WD (H65W)AWD Petrol 1.6L 4cyl 75kW 4G181584cc 75kW (Petrol) 1999MitsubishiPajero iOQA SUV 1.8 GDI All-wheel Drive (H66W, H76W)AWD Petrol 1.8L 4cyl 88kW 4G93 (GDI)1834cc 88kW (Petrol) 1998MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 1998MitsubishiNimbusUG MPV 2.4FWD Petrol 2.4L 4cyl 96kW 4G64 (16V)2351cc 96kW (Petrol) 1997MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol) 1996MitsubishiLancerCJ_A, CE Coupe 1.8 i (CJ5)FWD Petrol 1.8L 4cyl 86kW 4G93 (SOHC 16V)1834cc 86kW (Petrol)
Sorry ei onnistunut koko taulukko.
IGNITION COIL - MITSUBISHI GALANT VR-4 EC5# 1996-2003 - 2.5L V6 - CC315
Fuelmiser
Specifications
SKUCC315-6e4863f163e630e5d54Model #BrandFuelmiserFitment Location #Quantity Per Car #3PACK INFO #Contains 1 item(s)NOTE #COIL ON PLUG: BOOT & TUBE LENGTH 124MMPART DESCRIPTION #Ignition Coil and Igniter - Waste Spark Coil over Plug
VEHICLE SUITABILITY #
Vehicle: MITSUBISHI GALANT VR-4 EC5# 2.5L 6A13TT DOHC-PB 24v Twin-Turbo MPFI V6: 5sp Auto AWD: 4D Sedan
Manufacture: 1/01/1996 - 31/12/2003
NOTE: COIL ON PLUG: BOOT & TUBE LENGTH 124MM
Vehicle: MITSUBISHI GALANT VR-4 EC5# 2.5L 6A13TT DOHC-PB 24v Twin-Turbo MPFI V6: 5sp Man AWD: 4D Sedan
Ja sitten jos hakee noilla toisilla mitsuilla sytytypuolaa niin hinnat ovat parista kympistä eteenpäin.
Onko kellään kokemuksia?
Webtrap_86
Well-Known Member
Toimihenkilö
16 Huhtikuu 2004
Lahti
Sanoisin et väärät on tarjolla. Koska tuosta listasta niin niissä eri puolat kuin vr4 sen.
