ARP kansipultit eroja?
Mr mmc
CS5W ralli///art
18 Maaliskuu 2004
Polvijärvi
tuli vastaan kahdet erilaiset ARP pultit
"2.0L, 4-cylinder, 16 valve, M12, 4G63 up to 1994"
ensimmäinen vaihtoehto: 207-4201
toinen vaihtoehto 207-4701
12-Point Nuts U/Cut Studs VS. 12-Point Nuts
tarkoittaa mitä ???
20dollaria hinta ero ???
Vs: ARP kansipultit eroja?
http://www.frsport.com/ARP-207-4201-Mitsubishi-2-0L-4-Cylinder-16V-Head-Stud-Kit_p_24591.html#2
http://www.frsport.com/ARP-207-4701-Mitsubishi-4G63-M12-Head-Stud-Kit_p_24595.html#6
Tuossa ainakin visuaaliset erot...
Mr mmc sanoi
tarkoittaa mitä ???
Lainaus tuoteluettelosta:
"You will also note that ARP offers specially undercut studs for several engines. This procedure (done only to the shorter
studs) more equalizes the “stretch” of both studs, which makes for a more consistent clamping force – and one that compensates
for head gasket compression when the cylinder heads are installed. This helps prevent blown head gaskets, and assures optimum
engine sealing!"
