Vs: Outlander 2008 bluetooth paritus ei onnistu
Pairing a cellular phone
To use the Hands-free Bluetooth® cellular phone interface system with voice recognition, you need to pair a Bluetooth® compatible cellular phone to the Hands-free Bluetooth® cellular phone interface system with voice recognition. The Hands-free Bluetooth® cellular phone interface system with voice recognition can register up to a maximum of seven Bluetooth® compatible cellular phones. However, of the cellular phones registered, the cellular phone with the highest priority level will be automatically paired to the Hands-free Bluetooth® cellular phone interface system with voice recognition.
NOTE:
● Several Bluetooth® compatible cellular phones may not be compatible with the Hands-free Bluetooth® cellular phone interface system with voice recognition.
Use the following procedure to pair a Bluetooth® compatible cellular phone to the Hands-free Bluetooth® cellular phone interface system with voice recognition. 1. Stop your vehicle in a safe area, put the selector lever in the “P” position and pull the parking brake lever.
NOTE:
● A Bluetooth® compatible cellular phone cannot be paired to the Hands-free Bluetooth® cellular phone interface system with voice recognition, unless the vehicle is parked. Make sure you park the vehicle in a safe area before pairing a cellular phone to the system. 2. Press the SPEECH button. 3. Say “Setup.” 4. Say “Pairing options” 5. The voice guide will say “Do you want to Pair a phone, delete a phone or list paired phones?” Say “Pair a phone.”
NOTE:
● A maximum of 7 Bluetooth® compatible cellular phones can be registered. If 7 cellular phones are already registered, delete a phone and then pair the new phone (refer to “Deleting a phone” on page 5-90). 6. After the voice guide says “Please say a 4-digit pairing code,” say a 4 digit number. The 4 digit number will be registered as a pairing code for the phone. When the confirmation function is on, the system will confirm whether the number said is acceptable. Answer “Yes.” Say “No” to return to pairing code selection.
NOTE:
● The pairing code entered here is only used for the Bluetooth connection certification. It is any 4-digit number the user would like to select. Remember the pairing code as it needs to be keyed into the phone later in the paring process. Depending on the Bluetooth® connection settings selected, entry of this number may be required each time the phone attempts to “connect” to the Hands-free Bluetooth ® cellular phone interface system with voice recognition. Refer to your cellular phone owner's manual for connection defaults and settings. 7. The voice guide will say “Start pairing procedure on phone. See phone’s manual for instructions”. Refer to the owner’s manual for your cellular phone and enter into the phone the pairing code that was registered in Step 6.
8. When the system finds a Bluetooth® compatible cellular phone, the voice guide will say “Please say the name of the phone after the beep.” After you hear the beep, name the phone by saying a name of your preference.
NOTE:
● When the system cannot recognise the Bluetooth® compatible cellular phone, the pairing process will end and the system will beep and then return to normal status. Try the pairing process again after reconfirming whether or not the Hands-free Bluetooth® cellular phone interface system with voice recognition supports your Bluetooth® compatible cellular phone. 9. The voice guide will say “Assign a priority level between 1 and 7. One is the highest priority.” Say a number between 1 and 7 to set a priority level for the cellular phone.
NOTE:
● If you selected a priority level that has already been set for a different phone, the system will ask you whether you wish to overwrite that priority level. To overwrite the priority level, answer “Yes.” Answer “No” to return to the priority level selection in Step 9. 10. After the voice guide says “<phone tag> set to priority <priority>,” the system will start the pairing process. Wait a moment for the pairing process to complete. When the confirmation function is on, the system will confirm the assigned phone name and priority again. Answer “Yes.” Answer “No” to return to the priority level selection in Step 9. 11. When the pairing process is completed, the voice guide will say “Pairing Complete.” The system will then beep and the voice recognition mode will be deactivated.
Selecting the phone
When multiple paired phones are present in range of the Hands-free Bluetooth® cellular phone interface system with voice recognition, the phone with the highest priority (set during the paring process) will be connected to the system. Use the following procedure to connect to another pair phone with lower priority. 1. Press the SPEECH button. 2. Say “Setup.” 3. Say “Select phone.”
4. After the voice guide says “Please say,” it will read out each priority number and phone name pair in order, starting with the phone that has the highest priority level (from 1 to 7). Say the priority number of the phone that you want to connect to.
NOTE:
● You can connect to a phone at any time by pressing the SPEECH button and saying the priority number, even before all of the priority number and phone name pairs are read out by the system. 5. After the voice guide says “<phone tag> selected,” the system will reconnect to the cellular phone. Wait a moment for the process to complete. When the confirmaion prompts are on, the system will ask you again whether the phone that you want to reconnect to is correct. Answer “Yes” to continue and reconnect to the cellular phone. If you answer “No,” the system will ask “Which phone please?” Select the priority of the phone that you want to connect to. 6. When the reconnection of the cellular phone is completed, the voice guide will say “<phone tag> will temporarily override phone priorities” and then the system will return to the main menu.
NOTE:
● To change the priority level of a specific phone, redo the pairing process for that phone (refer to “Pairing a cellular phone” on page 5-86).
