En löytänyt täältä joten tässä (jos löytyy nii tän voi poistaa). Koodien luku ilmeisesti onnistuu myös ilman testeriä/usb-piuhaa kytkemällä pinnit 1 ja 4 yhteen obd-liittimestä, vai? Kokeilen itse kun ehdin (ja editoin tätä viestiä).
Engine Codes
12 Air Flow Sensor System
13 Inlet temperature Sensor System
14 Throttle Position Sensor System
21 Temperature Sensor System
22 Crank Angle Sensor System
23 TDC sensor <SOHC> or Systematic Camshaft Sensor <DOHC> System Tong
24 Speed Sensor System
25 Atmospheric Pressure Sensor System <T / C>
31 Knock Sensor System
41 Injectors System
44 Ignition Coil, Systematic Power Transistor Unit
-- (No.1 - No.4-cylinder) <DOHC>
52 Ignition Coil, Systematic Power Transistor Unit
-- (No.2 - No.5-cylinder) <DOHC>
53 Ignition Coil, Systematic Power Transistor Unit
-- (No.3 - No.6-cylinder) <DOHC>
61 A / T-ECU And Communication Lines (Torque Reduction Request Signal Line) System
64 FR Alternator System Terminal
71 Vacuum Control Solenoid Valve System <T / C-A / T>
72 Ventilation Control Solenoid Valve System <T / C-A / T>
1A No.1 cylinder accidental fire detection
1B No.2 cylinder accidental fire detection
1C No.3 cylinder accidental fire detection
1D No.4 cylinder accidental fire detection
1E No.5 cylinder accidental fire detection
1F No.6 cylinder accidental fire detection
2C Multicylinder accidental fire detection
Transmission Codes:
11 Non TCL Car – Throttle Position Sensor System - Short circuit
-- TCL Car – Accelerator Pedal Position Sensor System - Short circuit
12 Non TCL Car - Throttle Position Sensor System - Disconnection
-- TCL Car - Accelerator Pedal Position Sensor System - Disconnection
14 Non TCL Car - Throttle Position Sensor System - Sensors misaligned
-- TCL Car - Accelerator Pedal Position Sensor System - Sensors misaligned
15 Oil Temperature Sensor System Disconnection
21 Crank Angle Sensor System Disconnection
22 Input Shaft Speed Sensor System Short-circuit / disconnection
23 The Output Shaft Speed Sensor System Short-circuit / disconnection
26 Stop Lamp Switch system Short-circuit
31 LR Solenoid System Short-circuit / disconnection
32 UD Solenoid System Short-circuit / disconnection
33 2ND Solenoid System Short-circuit / disconnection
34 OD Solenoid System Short-circuit / disconnection
35 RED solenoid system <5 A / T> Short-circuit / disconnection
36 DCC System Solenoid Short-circuit / disconnection
41 Complete Without a fast speed change
42 2-speed variable speed without having completed
43 3 speed complete control of transmission
44 complete 4-speed variable speed
45 complete a 5-speed variable speed <5 A / T>
46 variable speed complete retreat
51 Non TCL Car - Abnormal communication with the engine ECU
-- TCL Car - ASC-ECU abnormal communication
52 DCC solenoid system – Bad System
54 A / T control relay system - Earth short-circuit / disconnection
56 N range lamp system - Earth short-circuit
71 A / T-ECU abnormality
ABS Codes
11 Wheel-Speed Sensor (FR) System (Short or Break)
12 Wheel-Speed Sensor (FL) System (Short or Break)
13 Wheel-Speed Sensor (RR) System (Short or Break)
14 Wheel-Speed Sensor (RL) System (Short or Break)
15 Wheel-Speed Sensor System (Abnormal Signal Output)
16 ABS-ECU Power System (Voltage Abnormal Rise Or Decline)
21 Wheel-Speed Sensor (FR) System
22 Wheel-Speed Sensor (FL) System
23 Wheel-Speed Sensor (RR) System
24 Wheel-Speed Sensor (RL) System
27 2WD/4WD Systematic Detection Switch
33 SUTOP PURANPU SUITCHI system (ON disconnection or failure)
41 Solenoid (FR) System
42 Solenoid (FL) System
43 Solenoid (RR) System
44 solenoid (RL) System
**Note: 41 -42 **
**Each item in the corresponding solenoid DOBARUBU drive signal
**if there is no response or an ABS-ECU power system failure
51 Valve Failure Relay ON
52 OFF relay valve failure or power system failure ABS-ECU
53 OFF Motor ABS - ECU failure or power system failure
54 ON failure MOTARIRE
55 Motor System (Pump Motor Sticking), Or Abs-Ecu Power System Failure
63 ABS-ECU system
ASC codes
11 FR wheel speed sensor (Short or Break)
12 FL wheel speed sensor (Short or Break)
13 RR wheel speed sensor (Short or Break)
14 RL wheel speed sensor (Short or Break)
15 wheel-speed sensor system (abnormal signal output)
16 ECU supply voltage abnormality
17 TCL Group 13 H-switch system troubleshooting
21 FR wheel speed sensor system
22 FL wheel speed sensor system
23 RR wheel speed sensor system
24 RL wheel speed sensor system
25 Rear wheel speed sensor system (Simultaneous left and right rear wheel speed sensor burnout)
26 Rear wheel speed sensor system (Both of the rear wheel speed sensor failure)
27 Around the wheel speed sensor system (Both before and after the wheel speed sensor failure)
31 Ignition Switch (IG2) system
32 G-sensor system around
33 Stop Lamp Switch System (ON disconnection or failure)
35 Steering Sensor (ST-1, 2, N) line
36 Steering Sensor (ST-N)
37 Steering Sensor (ST-1, 2) systematic
41 FR Systematic Solenoid
42 FL solenoid system
43 RR solenoid system
44 RL solenoid system
45 FR diagonal cut valve system
46 FL diagonal cut valve system
47 FR Masu Sumi-to-pressure valve system
48 FL-pressure valve system
49 Accumulator valve diagonal line
51 Valve relay system (ON failure)
52 Valve system relay (OFF failure)
53 Motor system (OFF failure)
54 Motor system (ON failure)
55 Motor system (pump motor sticking)
61 A/T-ECU Group and the communications system
63 ECU fail
65 APS system, or TPS
66 TPS or APS system
67 APS system
71 G-sensor system
72 Yaw Rate Sensor System (Disconnection or short)
73 Master Cylinder Pressure Sensor System
74 Yaw Rate G-sensor system
75 Engine ECU
76 Engines and Communications System
77 TCL vacuum or Ventilation Solenoid Valve system
78 Pressure Accumulator Sensor System
81 brake fluid low
AYC Codes
12 voltage power supply (supply valve) system (short or break)
21 FR wheel speed sensor system (short or break)
22 FL wheel speed sensor system (short or break)
23 RR wheel speed sensor system (short or break)
24 RL wheel speed sensor system (short or break)
25 Different Diameter Tires
26 wheel-speed sensor trouble
31 Steer Sensor (ST-1, ST-2, ST-N) System (break)
32 Steer Sensor (ST-N) system (short)
33 Steer Sensor (ST-N) system
34 Steer Sensor (ST-1, ST-2) system (short)
41 TPS system (short or break)
51 before and after the G-sensor system (short or break)
52 G Sensors Around
56 Next G-sensor System (short or break)
61 Stop Position Switch System (break)
65 ABS monitor system (ABS malfunction or break)
71 Proportional Valve System (short or break)
72 Direction Valve (right) System (short or break)
73 Direction Valve (left) System (short or break)
81 Electric Pump Relay System (short or break)
82 Electric Pump Failure
83 Electric Pump Failure
TCL Codes
11 FR wheel speed sensors (or a short break)
12 FL wheel speed sensors (or a short break)
13 RR wheel speed sensors (or a short break)
14 RL wheel speed sensors (or a short break)
15 Wheel speed sensor system (output signal abnormalities
16 Power supply voltage abnormality of the ECU
17 TCL switch circuit system
23 RR wheel-speed sensor system
25 Rear wheel speed sensor system (left and right rear wheel speed sensors simultaneous disconnection)
26 Rear wheel speed sensor systems (both of the rear wheel speed sensor failure)
27 Around the wheel speed sensor systems (both before and after the wheel speed sensor failure)
31 Ignition Switch (IG2) strains
32 Circuits around the G sensor system
33 Stop lamp switch strains (ON injury or burnout)
35 Steering sensor (ST-1, 2, N) system
36 Steering sensor (ST-N) strains
37 Steering sensor (ST-1, 2) system
41 FR solenoid valve system
42 FL solenoid valve system
43 RR solenoid valve system
44 RL solenoid valve system
45 FR Cut valve diagonal strains
46 FL Cut valve diagonal strains
47 FR Masu Sumi-pressure valve system
48 FL Masu Sumi-pressure valve system
49 Pressure valve (FL-FR) system
51-Valve relay system (ON failure)
52-Valve relay system (OFF order)
53 Motor relay strains (OFF order)
54 Motor Relay system (ON failure)
55 Motor system (pumps, motors sticking)
61 A / T-ECU and the communication system
63 ECU fail
66 APS or TPS system
67 APS system
71 system next sensor circuit G
72 Yaw late sensor circuit system (or a short break)
73 circuit master cylinder pressure sensor system
74 Yaw late sensor or G sensor system
75 Engine ECU strains
76 Systematic communication with the engine ECU
77 TCL vacuum system or ventilation solenoid
78 Accumulator pressure sensor circuit system
81 Shortage of brake fluid
Engine Codes
41 Injectors System
Transmission Codes:
ABS Codes
**Note: 41 -42 **
63 ABS-ECU system
ASC codes
63 ECU fail
67 APS system
71 G-sensor system
75 Engine ECU
81 brake fluid low
AYC Codes
52 G Sensors Around
TCL Codes
63 ECU fail
67 APS system
