Manufacturer: Mitsubishi
Type: S-4
DOHC
16 valves total
4 valves per cylinder
Main bearings: 5
Bore x stroke: 85.00mm × 88.00mm
Bore / stroke ratio: 0.97
Displacement: 1997 cc 121.86 cu in
Compression: 9.00:1
Aspiration: Normal
Catalytic Converter: Y
Max. output: 132.8 PS (131.0 bhp) (97.7 kW)@6000 rpm
Max. torque: 167.0 Nm (123 lbft) (17 kgm)@4000 rpm
Coolant: Water
Specific output: 65.6 bhp/litre
Specific torque: 83.63 Nm/litre
Missä Mitsubishistä kyseinen kone on peräisin, olisin kiitollinen jos joku osaisi kertoa.
Type: S-4
DOHC
16 valves total
Main bearings: 5
Compression: 9.00:1
Aspiration: Normal
Coolant: Water
