Mitsubishi Galant 1987 E15 2.0Turbo RalliArt
28 Toukokuu 2015
Zagreb, Croatia
Hello folks, i have been working on this car for 5years now, its in family around 18years, second owner
A lot was done on this car, so i will try to represent it step by step, its a very detailed topic, for true lovers
so lets start
1987 Mitsubishi Galant 2.0Turbo RalliArt
Odometre
129xxx km
Engine Hardware
4G63T- 2.0T DOHC - 16v, 6bolt
xxxHP
Transmission
5 Speed MANUAL
gearbox from 2.4engine(4G64)
Engine Modifications
Vems standalone management system
Blow off-Turbosmart dual port
boost is on 1.2bar
exhaust 60mm(rear REMUS muffler)
intercooler from Galant TD
walbro 255lph fuel pump
intake box & k&n filter
560cc injectors from EVO9
Bosch lamda LSU 4.9
Bigger fuel filter, OEM from Eclipse 2G
EVO2 BIG 16G turbo
EVO2 manifold
EVO2 O2 housing
N/A throttle body
intercooler pipes from steel and polished
second ventilator for better cooling
water cooling for intercooler
Eclipse coils
hks turbo timer
Brakes:
Brake booster from Nissan S14 + brake master cylinder from Carisma GDi
wilwood 4pot brakes,310mm slotted and drilled willwood discs + ABS
rear standard Turbo
Suspension Modifications
Front:
Sport shocks+standard springs
Strut Brace
Rear:
Standard 2.0
Eclipse shocks+standard springs
Wheels & Tyre Modifications
17" original from Galant Ea0 Sport edition 1999
225/45/17
Exterior Modifications
Rain visors for front doors
Ralliart Body kit
white corner lights with LED orange turn signal in it + white bumper turn signal
RalliArt original side stickers
Interior Modifications
power mirrors
power windows
red light illumination
OEM EVO9 RS triple gauge set
On begining it was a stock 2.0(4G63) carb
Then I got a RalliArt body kit in very bad shape, and spend around 200hours to get it in lets say good shape
Some polished stuff
-JP-
31 Heinäkuu 2007
8
Vs: Mitsubishi Galant 1987 E15 2.0Turbo RalliArt
I really like your shiny parts !! Allmost too good to watch... :peukku
28 Toukokuu 2015
Zagreb, Croatia
Very RARE Turbo underneath plastics
With fitted body kit
I also got original digital dash
And some videos
http://www.youtube.com/watch?v=O4F5SVLCkmM
http://www.youtube.com/watch?v=yLPEfIUl6rk&feature=youtu.be
Then i got BRAND NEW rear RalliArt spoiler
New one is much better than old one
Then i got Wilwood 310mm brakes
28 Toukokuu 2015
Zagreb, Croatia
#6
So going with the engine
It was a stock 4G63 carb engine with 102hp
then i got original 2.0Turbo engine , known as a G63BT 8 valves, with 150hp
after some modding , adding up a intercooler, and settiong boost on 1.0bar it pulled out 175hp, but the power above 5000rpm was pretty bad
So i decided to go multipoint
i got a Megasquirt 2 Extra, intake manifold from 2.4 engine, 450cc eclipse injectors
after a lot of hard work, result was great, 227hp@5000rpm and 348Nm
Also then, i have painted a body kit, so all was looking much nicer
Niko Päivinen
Colt, Lancer, Pajero
1
Lahti
#11
Wau. The craftmanship is excellent, and special-extra-credit on starting a build on such a (nowadays) rare model. Anyone can just buy a new/newish car, and start putting bolt-on parts on it, but this is something else! Respect!
28 Toukokuu 2015
Zagreb, Croatia
#12
The story goes on
As turbo was very old, it starded smoking on idle, and i got a great deal on a DOHC engine, so the DOHC came in from eclipse, and i sold my engine to Austria
Then i started to rebuild the engine
First parts arrived
ARP head studs
set for balance shaft delete
injector rubber
oil filter x2
oil cap gasket x2
O2 housinga and downpipe 70mm gasket
engine dissasembled
then balance shafts are out, total weight save is 2.9kg
OEM part for oil pump housing
then the cleaning part
valve coer was in pretty bad shape
piston before and after
then next part was block
painted
28 Toukokuu 2015
Zagreb, Croatia
#14
Got OEM mitsu triple gauge set
galvanized bolts, and lines :D
lines looks like they are cromed
and how it should looked on the block
Main water pipe is now rust free , and completely galvanized from outside, as well as inside
received a package
Mitsubishi Genuine parts
ACL Race bearings, Perfect Circle Rings
All parts collected so far
Rings
sneak peak :D
thats all for tonight, tommorow next update
others , feel free to comment :)
-JP-
31 Heinäkuu 2007
8
#15
Faded HKS label at belt side of camcover looks truly unreal thing... :nykii ?!
28 Toukokuu 2015
Zagreb, Croatia
#18
new OEM parts
head cylinder is dissassembeled
exhaust valve, before and after
washed oil pump
all pistons are cleaned up, after 15washes
all is washed, and ready for install
valve cover painted
painted exhaust manifold, turbo housing, o2 housing and covers
oil pan cleaned up and painted, also a timing cover
28 Toukokuu 2015
Zagreb, Croatia
#23
machine work done
honed and surfaced block, surfaced valves, surfaced head, and a polished crankshaft
how it should look when i will start assembley
then i got mitsubishi eclipse 3g lifters
difference between 1g and 3g
next is cleaning, and working on a port job on the oil gallery on the block (where oil pump sits)
28 Toukokuu 2015
Zagreb, Croatia
#25
head on its place, torqed
thermostan housing, camshafts, lifters, rocker arms etc ,all in its place
its really nice to put all of those things together while they are so clean
thermostat housing
thread locker on the oil plug for oil gallery on the head
28 Toukokuu 2015
Zagreb, Croatia
#26
pice before and after galvanized
coil and power ignition mounts
then i got a third valve cover, painted in original silver with red letters combination
intake OEM gaskets and galvanized bolts
mediablasted intake manifold
before-after
and how an engine looks so far
1700 views and only a few comments??
DaJackal
EA5A, Z16A, CB4A, D22, E39A
10 Huhtikuu 2010
2
Lappeenranta
#27
Tomica93 sanoi
Most of us are still busy trying to jacklift our jaws up from the floor... and the rest have their hands busy fapping to this engine porn, hence the lack of comments. Astonishing work. :eek:
28 Toukokuu 2015
Zagreb, Croatia
#28
i got an exhaust turbo, manifold and o2 housing from evo2
Aisin water pump came in
i was in Budapest for a New Year and i got few (read a lot) spare parts for Galant
4 of us were in Budapest so i need to organized it very well
also i got rare genuine mitsubishi wheels for Galant / Sapporo 81-84, as far as i know there are 4 sets in my country, and i have 2 sets :)
i got genuine front brake pads for EVO3 calipers
oil pan is installed
J. Puhakka
Ylläpitäjä
7 Tammikuu 2003
4
#29
Yeah, I wish I could renew my old mitsubishis like that. Gasp. (Cordia / Colt)
MakeM
2 Elokuu 2008
4
#30
Tomica93 sanoi
Finns are quite recticent, and use words sparingly ;D
Really nice to look at a proper restoration job like yours. Keep up the good work :peukku
I bet all of the 1700 viewers agree with me.
How much the car is going to weight when ready?
28 Toukokuu 2015
Zagreb, Croatia
#33
finnaly i got the last package with parts
turbo is restored, had a few broken bolts in it, but now it is like new
Difference between Eclipse 1g and EVO2 exhaust manifold
Turbo is prepared
another round from galvanized
New and old water pump
New parts
also i got a new OEM fuel filter
New injector seals
Painted in black
Spark plug cables
Alternator
almost done, still have a few bits to put on
here are some pics of it, how it looks so far
28 Toukokuu 2015
Zagreb, Croatia
#34
Engine DONE!
here a few pics of a details
After a really hard work, and 9times getting the engine out and in, i finally got the right spot, and balance
all work i was doing completely alone
modified engine mounts
fitted OEM Mitsubishi EVO 9 RS triple gauges
MäTSi
Haittaakse?
22 Huhtikuu 2011
1
Paimio
#35
This is very impressive!!! :eek: Like engine porn or something like that. Whole project is awesome 8)
Keep up the good work. :peukku :peukku that kinda projects we need more.
Webtrap_86
16 Huhtikuu 2004
23
Lahti
#36
Nice work, specially with all detailing parts, theres no part wich hasn´t been restored. its going to be one fine mitsu. Keep doing it :peukku :peukku
28 Toukokuu 2015
Zagreb, Croatia
#37
Next job was wireing
it was all running okay, but all the wires are old and have some oxide on it, so i have decided to build a new wire installation
all is from fire proof wires
Installation done successfully , look like OEM
and connectors for ECU
[elle]
@Nordschleife
Toimihenkilö
7 Heinäkuu 2010
20
#39
wow! I am stunned.
I wish we will find the time and energy to do something like this to our old Colts as well...
Tomica93 sanoi
MakeM sanoi
... unless we are drunk ;D
I guess we are all so impressed that we do not find words.. and perhaps a bit ashamed because this is what many of us actually dream of doing but we just don´t get our thumbs out of our a**
Keep up that good work!
And all the best to Croatia! Lovely country and wonderful people! :peukku
28 Toukokuu 2015
Zagreb, Croatia
#40
After fitting the engine, next problem was that engine moved forward, so there wasnt many space for the pipe from air filter to the turbo.
So i bought a SPAL slim ventilator, as stock one is really deep
here is the problem
Comparasion
and fitted, looks like OEM
much more space now
after completing the engine bay(all hoses connected etc), iam really satisfied how it looks
-JP-
31 Heinäkuu 2007
8
#41
This photo and engine bay makes me cry... How beatyful life can be when mates are sharing Porn over internet... :) !
akio
impact green
Hallitus
16 Huhtikuu 2010
93
Lohja
#44
In finland we have this saying "jumalauta et on siisti" roughly translated "god help thats cool"
Astounishing work. Keep it up !
DaJackal
10 Huhtikuu 2010
2
Lappeenranta
#45
Completely new wiring and engine installation all by yourself? I'm beyond astonished. :nykii
28 Toukokuu 2015
Zagreb, Croatia
#47
So there are a lot of news lately, but slowly we will start with the new "phase"
car was hit by an old granny
and after a lot of time and patience, all was putted in the previous spot, and bumper was repaired with special material (small tube cost 100e)
28 Toukokuu 2015
Zagreb, Croatia
#50
After getting the car in the shape before accident, i have finally decided for a full respray
that means, fixing all the extra holes, and getting the "clean look" for the bolts for side skirts and rear bumper
also removing any rust surfaces from the doors and the body. A lot of hard work for removing everything and preparing it for painting
Finally removed all the parts from the car
