Vs: 4G63 moottorin kiristysarvot
84-93 galantit :
TORQUE SPECIFICATIONS Items Nm ft.lbs.
Engine mount insulator nut (large) 60-80 43-58
Engrne mount insulator nut (small) 30-40 22-29
Engine mount bracket nut and bolt 50-65 36-47
Front roll stopper insulator nut 50-65 36-47
Front roll stopper bracket to center member 40-50 29-36
Rear roll stopper insulator nut 40-50 29-36
Rear roll stopper bracket to crossmember 40-50 29-36
Transaxle mount insulator nut 60-80 43-58
Transaxle mount bracket to body 40-50 29-36
Fuel high pressure hose to fuel rail 4-6 3-4
Accelerator cable adjusting bolt 4-6 3-4
Front exhaust pipe clamp bolt 30-40 22-29
Front exhaust pipe to exhaust manifold 40- 50 29-36
Power steering oil pump to bracket 35-45 25-33
Air conditioning compressor to bracket 23-27 17-20
Oil pan drain plug 35-45 26-33
Oil pan 6-8 4-6
Oil screen 15-22 11-16
Timing belt cover 10-12 7-9
Cylinder head bolt (Cold engine) 90- 100 65-72
Camshaft sprocket 80-100 58-72
dater pump pulley bolt 8-10 6-7
Crankshaft pulley bolt 20-30 14-22
Crankshaft sprocket bolt 110-130 80-94
Timrng belt B tensioner bolt 15-22 11-16
Tension pulley bracket bolt 23-27 17-20
Right silent shaft sprocket bolt 34-40[43-49]*1 25-29[31-35]*2
Oil sprocket nut pump 50-60 36-43
Control wiring harness and intake manifold plenum or air intake manifold 4-6 3-4
Front roll stopper bracket bolt 55-75 40-54
Front engine support bracket bolt 50-70 36-51
Exhaust pipe support bracket bolt 30-42 22-30
Left engine support bracket bolt 30-42 22-30
Rear roll stopper bracket bolt 110-130 80-94
Front case bolt 20-27 14-20
Bear cover bolt 5-7 4-5
distributor nut 1O-13 7-9
Rocker arm and shaft assembly bolt (large) 19-21 14-15
rocker arm and shaft assembly bolt (small) 20-27 14-20
ntake manifold stay bolt 18-25 13-18
timing belt tensioner spacer and bolt 43-55 31-40
NOTE
*1: When a 2.0 mm (.08 in.) thick washer is used.
*2: When a 2.6 mm (.I0 in.) thick washer is used.
irroitus:
________________
: o o o o o :
: 4 6 9 7 1 : --> jakopää
: 2 8 10 5 3 :
: o o o o o :
kiinni:
________________
: o o o o o :
: 7 5 2 4 10 : --> jakopää
: 9 3 1 6 8 :
: o o o o o :
toivottavasti saa selvää :
