STi 2011 Sedan
pkleemola
3 Toukokuu 2009
Helsinki
The arch rival is back in town.
NETCARSHOW:
Subaru of America introduced a new 4-door version of the Subaru Impreza WRX STI performance flagship model. This will be the first time that the Subaru Impreza WRX STI has been offered in two body styles (5-door and 4-door). In addition to the new styling, the 2011 WRX STI features significantly revised suspension tuning and lighter 18-inch wheels for even sharper handling.
The Subaru Impreza WRX STI has been a recipient of continuous improvement since its introduction. Most recently, the 2010 WRX STI Special Edition previewed some of the suspension enhancements now migrated to the 2011 Subaru Impreza WRX STI. Thorough and painstakingly detailed chassis development, including testing on Germany's famed Nurburgring racetrack, has resulted in the best-handling Impreza WRX STI models Subaru has ever offered.
"The continuous evolution and development of the Subaru Impreza WRX STI is driven by the strong, loyal and vocal support from thousands of enthusiastic owners of this exciting high-performance vehicle," said Tom Doll, executive vice president and COO of Subaru of America, Inc. "The 2011 Subaru Impreza WRX STI 4-door will expand the appeal of this iconic performance model to a wider range of driving enthusiasts."
New Designs for 2011
In front, the 2011 WRX STI models feature sharpened bumper corners and wider, blacked-out fog lamp nacelles to accentuate the "wide and low" profile. A jutting lip spoiler with three-dimensional detailing emphasizes the cars' sporty intent. The newly designed front grille with black base and blacked-out Subaru wing highlights the headlights' shape to give the entire front end a more powerful appearance, accentuated by larger grille and bumper intake openings.
For the 4-door models, newly designed wider rear fenders are stretched out on the side beyond the tail lamps, accentuating a look of power and stability. The new design details contribute to an improved drag coefficient.
New Chassis Tuning for 2011
The Subaru Impreza WRX STI was already a highly optimized performance machine. Specific chassis tuning. Aluminum front lower L-arms reduce unsprung vehicle weight. Major chassis tuning changes include a lowered ride height and new pillow-ball bushings in front and stiffer bushings for the rear subframe that supports the double-wishbone suspension - these improve camber and toe stiffness.
Both the front and rear suspension systems employ higher-rate springs and thicker front and rear stabilizer bars than the 2010 model: 21 mm vs. 20 mm in front and 19 mm vs. 18 mm in rear. Spring rates have increased by 15.6 percent in front and 53 percent in the rear.
New standard 18-inch aluminum wheels feature high-luster paint and weigh 17.6 lbs. less than the previous standard wheels. The optional 18 x 8.5-in. BBS® forged aluminum-alloy wheels, which further reduce unsprung vehicle weight, are highlighted by silver high-luster paint for 2011.
Exclusive to the Subaru Impreza WRX STI, the Brembo Performance Brake System uses ventilated 4-wheel Super Sport anti-lock (ABS) disc brakes with Electronic Brake-force Distribution (EBD). Super Sport ABS can control the braking forces at each rear wheel independently, which optimizes braking ability during hard cornering to help reduce understeer.
The Ultimate Performance Subaru
The 2011 WRX STI continues as the ultimate-performance Subaru with its high-boost 305-hp turbocharged/intercooled 4-cyl. Boxer engine and 6-speed manual transmission. The STI also features Multi-Mode Driver Controlled Center Differential (DCCD) version of Symmetrical All-Wheel Drive with three "Auto" modes, as well as a manual mode with six driver-selectable differential locking settings.
The Subaru Impreza WRX STI is equipped with advanced dynamic control systems, as well: the Multi-Mode Vehicle Dynamics Control (VDC) stability and traction control system is standard and features a track performance-optimized mode; Subaru Intelligent Drive (SI-DRIVE) technology allows the driver to tailor the car's driving characteristics by choosing from among three selectable modes - "Intelligent," "Sport" and "Sport Sharp" - using a rotary dial on the center console.
The 2011 Subaru Impreza WRX STI models arrive in Subaru dealerships in late summer 2010.
Sporty, Spacious and Versatile Interior
New for 2011, the WRX STI interior is finished in black and silver to highlight its sporty design. Trim panels, the steering wheel air bag cover and steering wheel switches are now dark cast metallic.
The standard tilt and telescopic steering wheel is a three-spoke, leather-wrapped design embossed with the STI logo and features control switches for Bluetooth® hands-free phone function. A new AM/FM stereo with single-disc CD player features Bluetooth audio streaming and hands-free calling, iPod control capability, a USB port, 3.5mm aux. input jack and XM/SIRIUS satellite radio (subscription is extra). An available navigation system integrates a vehicle information center and Bluetooth hands-free calling.
Vs: STi 2011 Sedan
No mikä se tämä on onko Subaru hakkerit iskeneet sivuille??? ???
Vs: STi 2011 Sedan
No jos et ymmärrä niin opiskele vähän lisää kultista nimeltä EVO ja sen arkkivihollisista. :)
ps. kiitos tasokkaasta keskustelunavauksesta. Se oli täyttä paskaa.
Vs: STi 2011 Sedan
Hyvältä näyttää :peukku Edellinen malli oli kyllä susiruma...
Vs: STi 2011 Sedan
Onhan nää ratapäivätkin "Sinisten" elikkäs subarulaisten kanssa yleensä käsi kädessä järjestetty. Siis ne missä ajetaan radalla, ei nämä paljon kiistellyt OFF ROAD tapahtumat.
Vs: STi 2011 Sedan
Shadow sanoi
Ihan nykyinen malli se kyllä vielä on.
Tietääkseni tuon sedanin markkina- alueeksi on kaavailtu pelkkä USA. Omasta mielestä HB on paljon paremman näköinen kun tämä vanhoihin kaavoihin jäänyt sedanilookki.
Vs: STi 2011 Sedan
Kyllä sedani aina pesee eurooppalaistyylisen seat-kauppakassi-lookin, hyvä että tajusivat ottaa korimallin takaisin. En ole markkinatilastoja seurannut mutta veikkaan että myynti tulee nousemaan kovasti verrattuna siihen että pelkkää hb:tä olisi myynnissä.
Vs: STi 2011 Sedan
Aihe on lähellä sydäntäni johtuen paljolti siitä, että olen yhden STi:n ensirekisteröinyt. Se oli MY06, 370hv ja 540nm. Tämä nykyinen Evolution on absoluuttisesti ehkä parempi auto, mutta tuohon Imppuun suhtautui pelonsekaisella kunnioituksella viimeiseen päivään asti. Bokserin soundit 3" putkella toivat mielettömän subjektiivisen feelgood-factorin. Katuslickeillä sladit kun eivät lähteneet IX:n tyyliin progressiivisesti vaan kuin veitsellä leikaten ja leveinä. Se oli autojen Mötley Crüe.
Mielestäni parasta on, että STi on nyt yleensäkään tarjolla sedanina. Totta kai tuon kokoinen sedan on tilankäytöltään järjetön, mutta mitä sitten - ei voisi vähempää kiinnostaa. Mielenkiintoista on, miten nuo 2011 muutokset vaikuttavat nykymallin turhan pehmeään ajettavuuteen. Toivottavasti myös Suomeen saataisiin Spec-C tai jopa RA-R tai R205 (ei siis S205).
Vs: STi 2011 Sedan
Tykkään tosi paljon, ei voi mitään. Tosin bugeyeta lukuunottamatta kaikki Imprezat on kyllä mun mielestä upeita laitteita ja kuulostaa vielä paremmilta kuin miltä näyttää.
Vs: STi 2011 Sedan
Hienoja laitteita noi subarut! Varsinkin toi uusi sedan STi, kelpais kyllä mullekki.
Ex. Impreza wrx oli kyllä mahtava auto, tykkäsin kovasti, mutta onhan tämä evo hieman eri maata.
Ainoa mitä evossa kaipaan on juuri noi boxerin äänet. Olisi hauska kokeilla uudempaa STi:tä niin voisi verrata Evoon.
Vs: STi 2011 Sedan
Toi subarun keula on kyllä niin r****ksen ruma että hirvittää.Vieläkö nämä uudet boxerit vie hirveitä määriä löpöä tehoon nähden vai onko tuota boxeria hiottu jo paremmaksi?Plussaa tulee kyllä subarun äänistä..melkein yhtä tunnistettava ku audin 5 mukinen jossei sit ala kuplan koneeseen sekottamaan.
Vs: STi 2011 Sedan
http://www.blogcdn.com/www.autoblog.com/media/2010/04/01wrxstiny2010live.jpg
http://www.autoblog.com/gallery/new-york-2010-subaru-impreza-wrs-sti/#7
i laik! :peukku
Vs: STi 2011 Sedan
enti mut toi perä on komia omaan silmään. Lamppujen muotoilu perässä tosin vähä sitä ja tätä mut keulassa vastaavasti oikeen siisti. Kokonaisuudessaan miltei kilpailee evon kanssa.
Kai tää on niinku uus evokin et mitä enemmän kattoo niin siistimmäks tulee, ensalkuun se oli aivan kamala omaan silmään :D
Vs: STi 2011 Sedan
UITTO- sanoi
Sama täällä, muuten onnistunut muotoilu mutta takapään lamppujen muotoilu ei syki. Mutta jokatapauksessa sedanina paremman näköinen kun töppöperänä. Vois harkita jos tulis suomeen kohtuuhintaisena :peukku eiku :-[
Vs: STi 2011 Sedan
Vähä sama juttu ku evo x. Eestä on tosi jees mut takaapäin ei toimis etes pussi päässä 8)
Vs: STi 2011 Sedan
Shadow sanoi
Juuri näin. Tämän vuoksi ajankin ix:llä. Mutta jos sais valita niin 6.5 evo.... 8) tai originaali IV koppanen supra uutena tai uusi nissanin GTR.. ;D
Haaveillahan saa...
Vs: STi 2011 Sedan
ewopower,
juuri samoja ajatuksia. Koeajoin Evo X:n ja STi MY09:n. Molemmat hienostuneempia kuin nämä Viimeiset Samurait (Evo IX ja hawk-eye STi), mutta niin pehmeitä, niin pehmeitä. Esim evo IX:llä voi lähestyä mutkaa käytännössä missä kulmassa tahansa ja selvittää sen tyylillä... ;)
STi aliohjasi ja Evo X eristää kuljettajan actionista...
--> Jatkan säästämistä GTR:n / GT3:n.
Vs: STi 2011 Sedan
pkleemola sanoi
Mukava huomata ,että on saman henkistä porukkaa.
Kyllähän tuo Subbe sedanina on se ehkä kiinnostavin vaihtoehto sinisestä mallistosta. Hyvä ,että tuovat sen takaisin.
Vs: STi 2011 Sedan
Shadow sanoi
täytyy kyllä todeta, että on toi sedan imppu peräpäästä paremman näköinen kuin evo x. muutenkin huomattavasti härskimmän oloinen kuin hb.. :peukku
Vs: STi 2011 Sedan
mitä tulee tuohon STI:in niin sedan on paremman näköinen kun hätspäkki.
mutta mä tykkään 06-07 sti:stä enempi.ja tämä nykyinen ix on hieno ja hyvä peli ajaa.
ja sitten se kolmas juttu lisäten,jos jostain taion satatuhatta ylimääräistä niin pihassa on heti nissan GTR 8)
on se vaan helvetin munakas peli :p
Vs: STi 2011 Sedan
Ihan menevä. Oma silmä on jo tottunut siihen HB malliinkin, en pistäisi vastaan jos joku mulle sellaisen haluaisi lahjoittaa.
Hauskaa että Subaru heräsi peliin mukaan. Zero/Sports rakensi oman näkemyksensä uudesta sedan STi:stä jo viime vuoden puolella. Aika lähelle osuu Subaru näkemystä.
Subaru Impreza Czs Type Z:
Klik
Klak
Riks
Raks
Ja toimii hienosti ilman takasiipeä. :peukku
edit: Artikkeli tuosta CZs TypeZ:sta...
edit2: Siis tuo zero/sportsin autohan on tehty aivan tavallisesta sedanista istuttamalla Sti tekniikka uuteen koriin. Perän levityksetkin ovat autoon jälkikäteen muovatut.
Vs: STi 2011 Sedan
Muhun taas nuo Subarut ei sitten iske yhtään. Määrätynlainen kunnioitus noihin löytyy mutta silmää ei miellytä vaikka kuinka pitkään makustelisi. Mutta onhan ne, Subaruja. :D
Vs: STi 2011 Sedan
_AH_ sanoi
Klik
Klak
Riks
Raks
Uijui! Kyllä on hyvä ilman siipeä! :)
Itse olen sitä mieltä, että Evo ja STI ovat aina olleet kilpasilla keskenään ja se on hyvä asia. Pitävät jätkät varpasillaan ja kehittää uutta tekniikkaa "edukkaisiin" urheiluautoihin.
Tällä hetkellä tuo EVO 6 on vielä "kaunein" mitä tiedän, mutta tuo uusi siivetön sedan STI on kyllä aika kutkuttava.. Sinisenä ja 5-puolaset vanteet valkosena.. 18".. uijui.. sit ehkä.. :)
Vs: STi 2011 Sedan
Pumpkinca sanoi
Hiomis-hommista en tiedä mitään, mutta ensimmäiseen kysymykseen voin vastata: ei.
Tietenkin pienellä varauksella, että mikä katsotaan uudeksi.
Toki kannattaa käydä tehtaan jäljiltä säädättämässä.... joku vois käyttää termiä upgrade tässä yhteydessä ;D, niin kulutus senkun pienenee kerta kerralta.
Parin kerran jälkeen tultiin yhteensä 1,5 litraa alaspäin keskikulutuksessa.
Vs: STi 2011 Sedan
Siis nyt on kyllä pakko myöntää että on hyvän näkönen scooby.
Vs: STi 2011 Sedan
Omasta mielestä Evo 10:n perä on paljon paremman näköinen, ilman siipeä etenkin. Subben takavalot muistuttaa vähän uutta Ladaa tai edullisia korealaisia. Mutta toki makuja on moneksi. :) Muuten kyllä erittäin linjakas laite.
Vs: STi 2011 Sedan
Oma mielipide on että sti:hin ja evoon kuuluu takaspoikka!
Oli auto minkä mallinen tahansa!
Vs: STi 2011 Sedan
nikob sanoi
Suomen rajoituksilla siipeä ei ehkä tarvise, mutta Saksan baanoilla se alkaa olla oikeasti toiminnallinen varuste, ei mikään koriste tai ulkonäkötekijä.
Näin voi käydä suoralla(!) 290 km/h vauhdissa ilman siipeä, mutkassa nostaminen paljon pienemmässäkin nopeudessa riittäisi:
http://www.youtube.com/watch?v=-0oJ2wQiu2Y
