- Liittynyt
- 7 Tammikuu 2003
eli kuva ja tekstiä lehdistötiedotteesta:
Mitsubishi Motors launches Lancer Evolution IX hi-performance 4WD sports sedan
Tokyo, March 2, 2005 — Mitsubishi Motors Corporation (MMC) today announced that the Lancer Evolution IX high-performance 4WD sports sedan would go on sale at affiliated dealerships throughout Japan on March 3, 2005. With a 2.0-liter intercooler-turbocharged engine powering all four wheels through an electronically controlled 4WD system, Evolution IX raises all dynamic performance parameters to a new level. Tax inclusive prices range from 2,940,000 yen to 3,570,000 yen.
Evolution IX marks the 12th model in the series, which has also included an automatic transmission model, since the Lancer Evolution debuted in October 1992. Major features distinguishing the latest model include the adoption of Mitsubishi's proprietary MIVEC*1 variable valve timing technology in the intake system and improvements to the turbocharger that result in higher torque and produce better response for improved engine performance across its full rev range. New front and rear bumpers bring both high aerodynamics and cooling performance.
Evolution IX is offered in three trim levels. The flagship GSR grade features Mitsubishi Motors' cutting-edge ACD*2 + Super AYC*3 + Sports ABS*4 electronically controlled all-wheel control component system and a 6-speed manual gearbox. The motorsport-specification RS uses a special lightweight body, a new titanium-magnesium turbocharger, 5-speed gearbox and ACD + mechanical rear LSD all-wheel control. New for Evolution IX is the GT grade that brings together RS's turbocharger and drivetrain specification and GSR's comfort-bias body with its enhanced sound deadening. Allowing owners to customize their Evolution IX's to individual needs and preferences, a comprehensive range of factory- and dealer-fitted options as well as Ralliart tuning and dress up parts are available.
I . Product features
1. Exterior
In an integral molding, the new front bumper houses an oversize mesh grille to raise engine cooling efficiency and also locates the Mitsubishi 3-diamond emblem. All unnecessary openings on the undersurface of the bumper have been closed off to reduce air resistance.
The new rear bumper features a diffuser undersurface in a distinctive design that shapes the corners to stabilize air flow detachment and reduce drag and that adds to Evolution's sedan-racer looks.
The rear wing assembly uses molded vertical components color-keyed to the body and a carbon-fiber hollow spoiler that lowers the center of gravity.
Dark-clear extensions on headlamps and rear lamps enhance the car's premium appearance.
GSR and GT trim levels run on Enkei 17x8JJ lightweight 5-double-spoke alloy road wheels that are 0.15 kg per wheel lighter than those fitted to Evolution VIII MR.
Evolution IX is available with a new air dam extension and rear wing Gurney flap (dealer options) that further improve aero efficiency. These advanced aero devices improve high-speed handling and stability by reducing front and rear wheel lift and enhancing the front-rear aero balance.
2. Interior
Dashboard ornamentation on GSR and GT models is clear coated with a rich carbon-like finish.
GSR and GT models use new alloy accelerator, brake and clutch pedals designed for sport driving as well as to accent the sedan-racer look to the cockpit.
GSR uses Recaro bucket seats. The squab facing uses non-slip Alcantara suede upholstery that keeps the occupant fresh and comfortable even on longer journeys while the side bolster facings are covered in genuine leather making the seats easier to get in and out of and also adding a touch of choice luxury to the interior.
GSR is equipped with a carbon shifter panel embellished with the Lancer Evolution logo.
GSR and GT models use a high-density dash silencer and double-sealing weatherstrips that reduce interior noise levels.
3. Engine & transmission
For Evolution IX the 4G63 engine gains Mitsubishi's MIVEC variable valve timing technology that improves top-end output as well as fuel efficiency. MIVEC technology allows GSR to return 10.0 km/l in the Japanese 10-15 mode driving cycle, equivalent to a three percent improvement in mileage.
On GSR, the turbocharger uses a lengthened diffuser to generate more low-end and mid-range torque (400 N-m(40.8 kg-m)/3000rpm) as well as bring a significant improvement in response (average 5%) across the full rev range.
On the RS and GT, the turbocharger compressor wheel uses magnesium alloy instead of aluminum alloy. This brings a dramatic improvement in supercharging response. Mated to a 5-speed gearbox with higher torque capacity, the engine has been tuned to generate maximum torque of 407 N-m(41.5 kg-m)/3000rpm.
The 5-speed transmission used on the RS and GT derives from the close-ratio competition gearbox but has a revised top gear ratio for improved high-speed cruising.
4. Other features
New rear springs lower vehicle height slightly, improving rear end stability (GSR and GT) and allowing the Super AYC to operate more effectively and improve steering response (GSR).
Features retained on Evolution IX include: Evolution's well-proven lightweight and high rigidity body featuring the aluminum roof panel pioneered on Evolution VIII MR (all grades); jointly-developed Bilstein hi-response shock absorbers (GSR and GT); Mitsubishi's ACD + Super AYC + Sports ABS electronically controlled all-wheel control system (GSR); and Brembo ventilated disc brakes (GSR and GT).
Mielenkiintoista, Mivec? , tosin taitaa jäädä ainakin aluksi Japanin herkuksi, ainakaan maailmanlaajusia suunnitelmia ei tiedotteessa mainita, vain domestic..
ps. Olenko harhainen vai näyttääkö tuo Evo7 + Evo8 yhdistelmältä? alvo
[ylläpito on poistanut liitteen]
1. Exterior
2. Interior
4. Other features
